hysteria »
https://forums.nicoclub.com/hysteria-u25294.html
Tue May 17, 2005 6:25 am
translation, (i think):i am swapping a sohc engine for a dohc engine. what parts are interchangeable between these 2 engines. i want a 12 second car. what can i get cheap, what do i NEED to spend money on.
not sure about the interchangeablilty issue. i think there are a lot of parts that will work on both engine. i currently have an sohc, and a dohc, and they look very similar, except for the obvious differences in head and manifolds.
as far as what you can go cheap on: you can get everything cheap except fuel management... if you want a 12 second car and you don't have good fuel management then you'l blow up the engine for sure...
