yep... i went to the 1/4 mile 2 weeks ago.. yea i have not good luck because i break the plastic engine mounts. its a sad history and burn 3 spark plug wires. they hit the exhaust manifold and since then car fails a lot.
what i did?....- change all lifters... old lifters were good.- new oil change but i didnt change oil filter.- new motorcraft spark plugs- i remove the agresive cam and install the stock cam.
when i asembly all parts, i use lucas oil because i want a good start.
so whats the problem i have now?
well the problem was a erratic idle with the agresive cam ( 278 ) and engine dances a lot at idle and hadnt power at high rpms... it was fine before went to the track.
i put the oem cam in the engine and start it today... it starts fine.. very quiet and engine dont dance but when engine warmed up, it starts to fail a lot... same problem... erratic idle... engine dances in the engine bay and then stop running.
could it be a stuck filter?? i remember i put some oil in it and maybe it was dirty...
engine fails a lot then its warm... problem its similar when some spark plugs wires fail or are damaged, but my spark plug wires are new. they are a garlo chevy spark plugs wires.
maybe a compresion problem???
i have like 500usd to buy some 5.0 HO engine here in my city .. direct plug and play but i dont want to waste all my money so some good advices on what i can do before i try another engine.
thanks =)
i miss the cam sound. now my car sound like and probe v6 =(((
