blackmax23 »
https://forums.nicoclub.com/blackmax23-u66692.html
Sat Sep 08, 2007 4:40 am
No, it won't make it worse because the plastic stock air intakes have so many bends, flat points, boxes, etc., that it restricts the air flow into the engine. Adding a CAI will def. improve your mid range - top end, but remember, the longer the the intake, the better top end, the shorter, the more low end torque you'll see. And the sound coming from an intaked vq is simply amazing. If I were you, I'd go with a CAI and get a nice cat back/y pipe with high flow cat and you will be amazed at the difference. But don't be concerned about losing hp if you get a CAI, but if you get a short ram, you might see a loss of hp because of the shorter distance to the throttle body, and because the air filter is sucking in the hot air of the engine! And it doesn't scream like the CAI's do. Good luck!
