maybe boost
Discuss topics related to the VH41DE, VH45DE, VK45DE, and VK56DE engines.
gs14racer
i think i can make it work, with a twin scroll t4 i might be able to get a 4 inch down pipe out the back if i cut a slot in the firewall for it, your thoughts on turbo size would be apreciated modest 450 whp goal.
anyone want to but headers lol
trick240sx
Car: cars
theres a guy name Taylor that is running 6 psi of boost and a custom map and roughly getting 450 or above. Hes on this VH forum. or check out my thread and you will see my planns
zerothread/296413
Modified by trick240sx at 12:39 AM 1/9/2008
SuperHatch
Car: 96 TLC
gs14racer wrote:anyone want to but headers lol
I'm interested in the headers... email me superhatch at gmail dot com
Florida240sx
Why not remote mount set-up? I'm doing for my ka-t. got a ne wfuel setup race cell and msd pump for $200 and then rmeove factory gas tank and you got that space for turbo. Scavenge oil pump I think was $260 and then just get osme lines made and you could probably just run a small pipe back up front.
kingkilburn
Car: '93 240SX
I know you use your car for drift and drag, so what kind of power band are you looking for? It's good to see you are keeping the VH.
clip14
yeah remote mount would be ideal with the amount of room you have in the engine bay. with a high compression, high displacement v8, you should be able to spool a big turbo with minimal lag despite the increased piping etc.
anyotherone
Car: '93 S13 coupe VH45
I have an S13 that I'm putting a VH into... I don't think you need a 4" downpipe for 450whp.
I'm considering two t28's with 2" downpipe or one larger T4 with a 3" downpipe max, because the clearance just isn't there for anything larger unless you really start hacking things up.
mtcookson
Car: 1991 Nissan 300ZX
1992 Iinfiniti Q45
and much much more
For the downpipe/exhaust I would go at least equal to if not slightly larger than the turbine housing output... you'd be surprised just how much more power you can get by adding .5" to a pipe diameter.
If the pipe is too small you'll have too much back pressure after the turbo naturally decreasing power but also slowing spool. Larger exhaust can allow the turbo spool faster, which means much more low/mid range power and upper range power.
What you don't want to go too big on is the manifolds pre-turbo. You can go too large on those making spool too slow. Generally a turbo manifold will be smaller than an NA's making comparable power or less while the exhaust after the turbo will be larger than an NA making comparable power or less.
Return to “VH45DE / VK45DE / VK56DE Forum”
