I have a 1993 240 sx and have had trouble with it starting refer to
zer...-help for the entire story
it still has the KA24DE in it and was wondering if the Check engine light on yours stays on when you turn the key on engine off
the reason i ask is i have checked the powers and grounds for the ECM and have found that it has both, all the ignition and fuel components check out according to the FSM and the trouble trees in it. and have been looking at the ECM as a possible cause
The FSM states "Diagnostic test mode 1: in this mode the red L.E.D. and the MIL in the instrument panel stay "ON" if either remain "OFF" check the blub in the MIL or the red L.E.D.... [crappy Cali model information]... MIL and red L.E.D. : "ON" when the ECM C.P.U. or CKP sensor is malfuctioning---"OFF": O.K."Reference Page 41 in the EF-EC section
when i check the codes it flashes a 55 which is "No malfunction" however if i am in the blub check mode the check engine light stays on and will not turn off. so i was wondering according to what the FSM is saying (if i am reading it correctly) that if the light stays on i have a problem in the ECM in one way shape or form, which could be a blown ECM...
Bottom line can someone run out and check see if their MIL stays on or if it doesnt or can correct my thinking on this matter THANKS!!
