Dattebayo »
https://forums.nicoclub.com/dattebayo-u729.html
Sat May 08, 2004 5:39 pm
I checked and the intake appears to be somewhere on the passenger side, but i cant tell where its pulling from. Maybe from inside the door or the upper hood area.
As for the #4 position, thats a wiring issue. Take off the a/c control face and jiggle the wires that come out of it. If it comes on and goes off we have the problem. If not i guess that its the connection at the blower motor (behind the glove compartment).If neither of these work, you may have to replace the fan switch its self, which can be removed from the a/c control unit and replaced easily using a flat blade screwdriver.
