slidingsideways13 »
https://forums.nicoclub.com/slidingsideways13-u129154.html
Mon Mar 30, 2009 7:34 pm
Ok so my ka24de has what I suspect as a fuel problem...I thought it was ignition timing so I re did that like 3 times still no start just strong cranking...So I could tell the car is loading up on way to much fuel so I decided to unplug all my injectors to see if she would start on the fuel inside the block and sure enough she tries to start but seems like she is out of gas so I plug back in all the injectors and then all she does is crank she wont even try to start Now im confused ...even with 1 injector she just cranks until I unplug all the injectors then it trys to start...I have brand new plugs wires distributor cap rotor...Any Ideas thanks
