sonorous986 wrote:it might be a little too much, but maybe the ability to save two or three presets? like "street boost", "Track boost", etc., so you can push on button and have it set to 5 psi, then when you're at the track hit another button and have it up to 10 or something.
that should be pretty easy to do actually...
bruinbear714 wrote:I have thought about this and it isn't too difficult, considering my electrical engineering background. However, it'd be hard to find people who will be willing to try out the controller without guarantee & proof that it won't misbehave (overboost, spike, etc etc). That, and it'd be expensive to get a custom lcd screen unless you stick with the standard lcds, in which case won't be the same size as 99% of the boost controllers out in the market.
Now on with features - if I were to design the boost controller, I would have the ability to adjust the parameters of the control loop to cater to how I want the boost response to be. Another feature would be a built-in turbo timer since the two almost go hand in hand. I could care less about how it looks since it'll semi-hidden from view.
Good suggestions! I had never thought of letting the user adjust the parameters like that. For testing, the unit will be subjected to compressed air from a regular compressor to make sure it responds well before it ever goes onto a vehicle. I hope this testing idea will work, but if anyone has a better idea, I would love to hear it. As far as the LCD, yes I am having trouble locating an LCD of the "right" size, but I will keep scouring until I find something that will somehow work. If that doesnt work out, I guess I could always go back to an LED display =/
Could anyone post the dimensions "most" boost controllers are? Would it be bad if this unit was a different size?
I was thinking about more features: how does everyone feel about datalogging? I wonder how much something like that would be used? How about some kind of user specified "overboost" warning? Like a pulsating LED that goes off to remind you when you are nearing your car's "safe limit" so you dont go overboard cranking the boost up. Or, maybe it could be set up such that when you enter the "programming" mode on the unit, you can change the maximum possible boost level so you NEVER exceed it...
Keep the thoughts coming guys
