Im not worried about detonation cause ill be on 110 octane when i do this. I wana see how much pressure it will hold solid.... Then back it off 2-3 pounds and set it there on my boost controller and tune it to that level... and hope i can get about 350-375 whp...KATwo40 wrote:Most likely you'll reach the limits of the air intake temps and suffer detonation management issues at that boost pressure on your setup before you max out the injectors.
No the H3 refers to the compressor..Chezedik wrote:Similar to mine, although, I would assume H3 refers to the turbine.
Why wont a single walbro pump handle that much pressure if im using the stock fpr..??KATwo40 wrote:So, you're looking at topping out around 400-420whp, depending on fuel pressure and pump capability (please don't rely on a single Walbro 255).
Iamjohnhayes wrote:show me a compressor map and i shall tell you or at least be able to get reasonable close
Walbro 255 tops out around 350-375whp. You'd be gettin' pretty close to the max. flow rate of that pump.rn240sx wrote:
Next step up, if I'm not mistaken, is either dual Walbro 255's or a Supra pump.rn240sx wrote:
What is the next step up..??
Another question... How much fuel pressure can the stock ka fuel rail support..???
What boost level is that..??A34D4ME wrote:From the map a couple of posts up it looks like you will be making heat at that boost level.
I don't know about that? Structure240sx is running at 500+ RWHP and has 1 walbro high pressure fuel pumpKATwo40 wrote:
Well i did 314 whp at 20 psi and the wideband they hooked to the muffler was reading in the 8's till about 5k rpm when it leaned out to 11's...Edub1 wrote:Anything above 375 HP according that map. Even the center island is only 75% that looks like an in-efficient unit across the board. Don't mean to bash your stuff but If you're looking for more power it looks like a turbo upgrade is seriously in order.
Edub1=A34D4ME. Sorry for change, damn cookies.
Ok, 29 psi from the compressor may be good and all, but i seriously doubt my .48 a/r on the turbine wont allow the compressor to keep its eff at that level... also, i doubt this turbine will even hit 29 psi and if it does, it wont even hold there... Unless someone here can vouch that their .48 turbine did hit and held 29 psi.....Chezedik wrote:I think we covered that, it becomes inefficent at 29lbs. Beyond that, there is no power to be made.
