Sugar »
https://forums.nicoclub.com/sugar-u163545.html
Sat Jul 24, 2010 9:45 pm
To make things simple, I have a GT2871RS. The wastegate is at 10psi (higher than had planned). Car has stock ecu, stock injectors, stock maf. This is what happens.
Car will build boost fine, but once it hits 4000rpm boost drops to 0, although the turbo will still be chugging away. The car will also run with a vac reading of 5-10psi after driving for a bit. The car did lean out, so im assuming it's maxing out the injectors/maf. But would that cause this issue? I would of assumed it was a wastegate issue but this is the 2nd turbo now.
Had no issues with the stock t25, there are no boost leaks (positive on this). I figured maxing the sensors the car would lean out and possibly get detonation. Just trying to determine if thats my problem.
