Hi, I have noticed in here a few times when people ask how much you can raise the fule pressure with an FMU on turbo N/A cars with stock, or aftermarket fuel injectors. I e-mailed Bell Engineering(as in Corky Bell) and they replied back to this answer for me. I thought some of you might find it interesting also.
Question I asked...
Hi, I recently purchased your 2025 (This is the B.E.G.I., or Cartech regulator that I asked about in another thread) regulator for my 95 Nissan HardBody turbo project and I was going through your instructions and I have a couple questions real quick.
First, I was a little nervous about using a rising rate regulator because I am afraid of one of my injectors failing under the increased load. To help relieve my mind I purchased a new set of high performance injectors from Venom(Python)Performance. Still a little worried I was reading through your instructions that came with the FMU and noticed where it says about how a 90 lb. injector can take up to 100 psi fuel pressure no problem. Does this also apply to a stock sized injector? Meaning that theoretically my injectors can handle the same abuse w/o incident? I am not sure of what my aftermarket fuel pump is capable of handling, but according to the pressure calculation in your instructions I will need approximately 90 psi fuel pressure at 6 psi boost. However I do know that this fuel pump will work because it is the same pump that is used with NSport Racing's 240sx turbo kit, that they set at 7 psi.
Answer......
"Any stock injector can take approximately 1000 psi before it can physically leak or be harmed.
The possibility exists that injectors over 100 #/hr can jam at pressures greater than 100, but no physical harm is done.
The weak point in all efi systems is the diaphragm of the stock regulator. These usually can't take much more than 150 psi.
If the fuel pressure goes up to the desired number at mid-range rpm then fades at higher revs, the pump is inadequate." (Turner)
I just thought that some of you considering running an adjustable rate regulator, or FMU, would find it interesting.
Here is the link to the installation instructions I referred to..
http://www.bellengineering.net/fmu2020instruc.html
Jason
Source:Turner, Stephanie. "Re:Just a couple simple FMU/Fuel Pump/Injector Questions."
[email protected]. 4/28/03
