1991q45 »
https://forums.nicoclub.com/1991q45-u127542.html
Fri May 22, 2009 2:02 pm
well i don't know if it's an issue but it did'nt start till yesterday.
it's a 92 maxima gxe auto. she just rolled over on 167k miles.
okay 1st-2nd shifts are delayed.no slipping.no flaring up then shift.
it's just delayed.
3500rpms and under no delay.wot no delay.the shifts are firm not to firm though.2nd-3rd no delay same for 3rd-4th.reverse is fine.
another issue is kickdown when your in 2nd or when she shifts 1st-2nd then u floor it it takes a second or two to realize to down shift.
i do happen to have a 4.7k ohm resistor in place of the line pressure resistor.(it's there for the firm shifts and quick kickdown response).
now here's where it gets intresting:when you remove the resistor not only are the shifts neck breaking hard they're quick and so are the down shifts.
i changed the transmission fluid about 25k miles ago (i know it's time to change it again).
can anyone here PLEASE shed some light on this?
thanks in advance!
