proimport17 »
https://forums.nicoclub.com/proimport17-u8668.html
Tue Aug 21, 2007 3:38 am
I have a 2000 Maxima that I just replaced the rear main seal in and now when I crank it it runs rough and stalls. I can richen it with propane and it runs fine so I know it's lean. I put a noid light on the injectors and they are all firing properly. I have rechecked all of the connectors that I had apart and they are fine. I had been told that sometimes when you remove the trans you may get a bad ground between the engine and bell housing when you reassemble it so I took it back apart and sanded both but with no improvement. Please let me know if you have any suggestions. Thanks in advance.
