MinisterofDOOM »
https://forums.nicoclub.com/ministerofdoom-u16506.html
Tue Jul 31, 2007 11:50 am
I would first start by checking your oil. The noise could simply be the result of low or very old/dirty oil.
Timing chain replacement is a pretty big job, especially in the cramped Maxima engine compartment. It can be done, but it's definitely a time-consuming job that I would only recommend to someone who is very comfortable with their mechanic abilities. If you screw it up, you could make things a lot worse.That said, if you think you can do it, then by all means save yourself the labor costs and try it yourself.
