DrLou »
https://forums.nicoclub.com/drlou-u124282.html
Wed Jan 16, 2013 7:22 pm
OK, Now this has become a real crisis - car absolutely will not even turn over!
Based mostly on advice here, so far:
I've replaced the Fuel Regulator Valve and verified the function of the EGR valve; EGR responds to vacuum, and moves full throw. I also cleaned the Mass Flow Sensor while things were apart; it looked perfectly intact and clean, fwiw...
After all that, the car is even more difficult to start. Symptoms are a severe, rough shaking, misfiring kind of behavior, thought it eventually starts. Feels really profoundly bad when this happens, as if the car is firing out of order (!); if it were a carburetted motor, I'd say it is behaving as if completely flooded.
Once the car does start, however, it's like a racehorse - it really runs great for a 140k+ car. (So it can't be the fuel pump - ( or can it? )) Through all of this, the CEL is not on.
Then, this morning, more starting problems... Tried about 5 start attempts, then plugged in the ODB diagnosis device - I've had codes for the knock sensor and an O2 sensor, on and off, for a couple of years. I've cleared all codes in the past, just to be sure they aren't spurious and, eventually, these two codes return.
This morning, though, after clearing codes, the starter will not even turn over! ( I doubt I've burned the starter...? )
What's up now? Can anyone offer some suggestions?
