audtatious »
https://forums.nicoclub.com/audtatious-u2438.html
Mon Mar 15, 2004 5:45 pm
Here's a thread of "How To's" and Information. If you have any you wish to add, please list them and I will add'em to the list by order of year. If posts are missing, below, please refer to the main thread at: HERE
General:----- Maxima Bulb Chart (all years) - audtatious----- Replacing CV boots - NISTECH----- Installing Wheel Spacers - Fezzik----- Strut Boot Info - phenryiv1 (see post in this thread - pg 1)----- SE gauge Install- phenryiv1 (see post in this thread - pg 1)
4th Generation(1995-1999.5):----- Auto to 5sp Conversion - hlh0501----- How to retrieve your CEL (Check engine light) codes - vbxmaxima----- What your CEL codes really mean - vbxmaxima----- How to change your spark plugs - VQpower.com----- How to replace your fuel pump - vbxmaxima----- How to replace your fuel injectors (front & rear) - vlad----- How to change your engine coolant - motorvate (Frank)----- How to change your power steering fluid - motorvate (Frank)----- How to replace your fuel filter - vbxmaxima----- How to troubleshoot your TPS (throttle position sensor) - vbxmaxima----- How to remove/install a valve cover - max-world----- How to install a MEVI (Middle eastern variable intake) - VQpower.com----- How to replace clutch slave cylinder hose - VQpower.com----- How to re-grease your starter - motorvate (Frank)----- How to wire your cooling fans for manual use - Jime (Jim)----- How to remove your speed limiter (model specific) - Ben Garner----- How to install Stillen supercharger (Part One) - max-world----- How to install Stillen supercharger (Part Two) - ericj----- How to clean your IAC valve ----- How to test/replace your knock sensor - motorvate (Frank)----- How to reset your SRS/Airbag light ----- How to replace your motor mounts ----- How to replace your oxygen sensors ----- 4th Gen Audio Wiring Schematics - audtatious
5th Generation Maxima (2000 - 2004):----- Front Speaker Replacement - audtatious----- Subwoofer Enclosure - audtatious----- Addco RSB Installation - audtatious ----- Fog Light Replacement - audtatious----- Injen Intake Installation - audtatious----- 5th Gen Audio Wiring Schematics - audtatious
