Maxima hesitation from a stop
CRCricket
Car: 1995 Maxima
My Maxima has been having a lot of trouble with starting from a stop, hesitating and being sluggish before finally moving. It's an automatic, but putting it into 1 has helped, and then shifting to 2 then D, but sometimes that doesn't help. I am no mechanic, and this is annoying. Any suggestions? I have had regular maitenance done to it, and I wonder if this is a fuel filter issue, but I would probably be wrong as that is too easy. I tried a Nissan dealership and they couldn't repeat the situation, and they couldn't get a read from the engine either.Thanks!Christine
NutriaforBreakfast
Car: Nissan Maxima 1995 VQDE engine
Is the engine fully warmed up when this happens?
Is the engine idling ok when in park? Is the idle ok in drive?
How does it run on the highway?
CRCricket
Car: 1995 Maxima
it happens after driving for a bit, sometime i can feel the hesitation while driving, including on the highway, but the worst is starting to go from a stop. It idles fine.
MCovington
Car: 1995 Q45
My 95 Max had a slight miss only after it warmed up the motor. I found a bad coil pack on the rear cyl. Replaced it and all was well. You could only feel it when it was under a load, no miss at idle or flat road driving. Drove me crazy for a long time.
CRCricket
Car: 1995 Maxima
It's starting to idle poorly...dropping down to 0-RPMS. It doesn't stall out completely, then will start to go, but it takes a few seconds to go while the person behind me starts honking nonstop. any answers help to diagnose this as I am going to take it back to my mechanic tonight for him to check out.
allensteiner
Car: 1995 Nissan Maxima GLE, 2005 Pontiac Bonneville SE
for the honkers behind you...give the the finger but seriously...no cel comes on?
Ops
Car: 95 Nissan Maxima SE
Hey they’re...
I couldn't help but to notice this post. It reminds me why I signed up on these Forums. I also have a 95 Max and have had experienced similar circumstances when going from a red light or even going at all after the temp gauge is at 1/2 with the jerk behind me.
And with all due respect... Give him the finger!
When I took it in they found out that my MAF (Mass Air Flow Sensor) was messed up. (Why the car had problems moving after temp warmed up at red lights or hesitating to move at all). Once they replaced it I have not had an issue since. Its pricy, you can get a used one for around $300 but that's being optimistic.
Is your CEL on? The codes from a diagnostic can yield results that may lead you in the right direction.
--She's a good car give her a chance, maintain her well and she will take care of you 400000 miles after the fact...
[email protected] @ https://opsec.spaces.live.com
johnnyd6404
Car: 2004 G35 Coupe 6MT 2k2 Maxima SE(sold) 2005 Altima 2.5S
Check the egr valve may be clogged. My girl had the same problem with her dodge. It threw no codes but it was so clogged I couldn't understand how the car even started.
nj1sh
Car: maxima 96
Same thing with mine. When the car is cold there is no hesitation but soon after it warms up it hesitates and is very annoying. Thats why I am thinking of changing all vacuum hoses and spark plugs. I do not know what the problem is.
