Maxima fuel filter?
schanne
Car: 93 Hatch-Sr20
So the filter is in the fuel pump, but I also read that It shouldn't go bad. The car does have 100k miles on it now.
The reason I ask is the ecu gave codes for p0171 p0174. Systen too lean
Mafs was cleaned and airfilter...
What are my possibles other than injectors? Should I replace the fuel pump/filter? 02 sensor?
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
There's a small sock filter on the pump's intake, but the "real" fuel filter is mounted on the firewall under the hood. It's near the center, and cylindrical.
Presscott707
Car: 1999 Maxima 5spd
do like minister of doom says and change the main fuel filter and the run some sort of fuel injector cleaner or seafoam just to clean out the system.
BOBCAT
Car: 2000 Maxima, 94 SER
MinisterofDOOM wrote:There's a small sock filter on the pump's intake, but the "real" fuel filter is mounted on the firewall under the hood. It's near the center, and cylindrical.
Do i have two fuel filters as well? How hard is it to replace both, and what all is involved? I went to autozone and they were trying to tell me i have to change the screen in the gas tank as well, so that would mean taking the gas tank off.
schanne
Car: 93 Hatch-Sr20
^^ Here is an install for the fuel pump. You don't have to drop your tank!I havn't looked yet for the fuel filter in the engine bay. Autozone said there is none, I cant even find a fuel filter for sale anywhere on the web.
Btw- this is a 04 maxima
MinisterofDOOM
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
No need to drop the tank. All you need to do is remove the rear seat. There's a pass-through port under the rear seat through which you can access the pump.
johnnyd6404
Car: 2004 G35 Coupe 6MT 2k2 Maxima SE(sold) 2005 Altima 2.5S
schanne wrote:^^ Here is an install for the fuel pump. You don't have to drop your tank!I havn't looked yet for the fuel filter in the engine bay. Autozone said there is none, I cant even find a fuel filter for sale anywhere on the web.
There is only one in an 04 it's part of the fuel pump here is a link to replace it. Its for an 02 but it should be the same.http://www.shiftice.com/fuel_filter.html
MinisterofDOOM
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
Also, something many people fail to anticipate (like myself, for example) is that the fuel filter cover has a rubber gasket that should probably be replaced. Not all fuel pumps come with a replacement gasket, so just make sure you have one on hand either way.
schanne
Car: 93 Hatch-Sr20
Thanx Guys!
