Maxima Clutch for SR any good?
240dreams
Car: 240's
I need a new clutch for my SR and Im on a tight budget. Is the stock maxima clutch worth dropping? Does it fit good and does it slip? Thanks ahead guys.
goldollar
Car: cars
Well the maxima clutch is oem unit for the SR, so there isnt any problem bolting it up, and if ur on a tight budget i would say y not not, u can get em for 50 -80 bucks depending on where u go and who u know. What are ur mods.
240dreams
Car: 240's
nevermind just ordered a spec stage 3
MadSideways
Car: Cars, women, drifting...the usual...heh
Holy moly, you realize that the stage 1 will hold 360lbs of torque, which is well over 400 flywheel horse power. I don't understand why people get UBER clutches.
I guess if you don't mind putting your entire body weight on the clutch at every light, then more power to you. Although because there's no slippage it'll be a pain in the arse if you hit traffic or a red-light on a hill.
Anyways, just my two cents...
Tai Mai Shu
The spec 3 isnt bad, as a matter of fact I will upgrade mine to a spec 3 next time (I have a spec 2) Now, and it basicly feels like stock...but holds 390ft lbs tq? I will need more than that...And if you like drifting you really need a better flywheel, because you use it alot...
