USsil80 wrote:would you say it is an UPGRADE such as heaat dispation and stopping area or would you say just get 300z
Better heat disipation because of the larger rotor, better stopping power, better selection of pads...The Z32 upgrade is a superior upgrade, but on most of our cars its more braking power than we need and also much more expensive than this upgrade...and you dont have to change ball joints or control arms or whatever...
I'm pretty sure you need the caliper bracket from the maxima as well...I'll double check tonight...I just bought a 'loaded' Maxima caliper set from O'reillys, everything you need except for the rotors...
Yes the 240 lines work, but they might run a little differently...
