Beancooker »
https://forums.nicoclub.com/beancooker-u42602.html
Thu Jan 11, 2007 5:12 am
If they still haven't come off, try to spray some PB Blaster or WD40 inside the rotor where it meets the hub. Spray it from the backside. If you are going to have the rotors turned and reuse them, be careful as to how hard to tap them. You don't want to warp or bend the rotors. If you will be replacing them all together, beat the crap out of them, and they'll come off. Just be careful as to not bend anything else. I'd still use a soft rubber mallet.
