asdean »
https://forums.nicoclub.com/asdean-u46189.html
Wed Aug 30, 2006 1:35 am
I have a 2000 Maxima SE with the automatic air-conditioning/heater system.
The auto air has always worked well, sending warm air thru the bottom vents (by the feet), and cold-air thru the middle vents (by the console/radio). In the winter I could set it at 68 degrees and forget about it, and it would always warm up the car just fine. In the summer, I would set it to 75 degrees and it would keep the car perfectly cool.
Suddenly, the system started acting really weird, and I can't figure out the problem. While cold air would never come out of the bottom vents in auto-mode before, now cold air comes out of the bottom vents, unless I crank up the temperature to over 82 degrees. If I set it any lower, it goes from warm air to cold air very quickly.
Has anyone else run into this ? I would really appreciate any ideas.
