maxima alternator help
HEslideFRESH
Car: 97 maxima
i have a 97 max GLE and my alternator just sh**ed on me. i looked at the alternator installed on the car and it says hitachi 12V/100Abut every place that i call to buy a new alt they tell me there is only a 125A or a 110A
so my ? is the cali emissions max a 100A that turns into a 110A or did someone install the wrong part?
also how would i know if i have a cali emission car or not thanks peeps
maxhopper
Car: 02 Maxima SE 6spd
As for the alternator, I could not see any labels or markings on mine. If you buy an OEM alternator, you will be assured that you have the correct one.
jltibbs
Car: 2015 Nissan Versa SL
1994 Infiniti Q45
2000 Infiniti I30
welcome aboard.
the dealership might be able to tell you whether or not you have cali or fed emissions. i believe that the alternator on the 4th gens runs about $500-$700 labor and parts, if you go with OE nissan alternator. the bad thing is, nissan will not accept anything but a nissan alternator as a core. (at least around here) good luck with it, and feel free to ask if you have any further questions.
Ryan Heo
Car: 1996 Infiniti I30
Hi,I replaced an alternator 2 month ago to 96' I30. I bought it on Autozone. They have thier brand alternator, but you can see "nissan" on the cover that is OEM part. It is remanufactured with nissan plastic cover. It cost about $250 which has core value. So the actual cost was $160.
If you have some tools like sockets, you can do it. It will take about 1 hour.You don't need to take cooling fan out if two people works. At first disconnected battery, and take the serpentine belt off, and A/C compressor. You can reach a long nut which is through the back side of alternator. Some harness work.
Thanks.
Beancooker
Car: Current Car: 2024 Tesla Model 3
Past cars: Way too many to list
I replaced mine when I had my Max, and it's as easy as Ryan says. You can use a higher amp alternator, and you will be fine. Actually, it is not a bad thing to have higher amps.
NutriaforBreakfast
Car: Nissan Maxima 1995 VQDE engine
You can buy alternators that have different outputs
For instance an alternator for an rv motorhome is more powerfuldue to all the electrical requirments
loystock
Car: 10 Honda Pilot
97 Infiniti Q45
03 Infiniti Q45
97 Infiniti I30
06 Infiniti M35 Sports
04 G35 & 99 I30-RIP
Before you buy from Autozone, be sure to check with Joe (Scottsdale Infiniti) or from their website at everythingnissan.com. They have a special shipping rate for this month - $5 flat.
The quality of parts from AutoZone, IMO, is much better than Kragen. Though both stores usually give a replacement warrranty (limited), it's a real pain when your alternator die and you are in the middle of nowhere. Not happened to me yet (knock on wood). However, buying and OEM is still preferred, as long as the price difference is not much.
Another way is to go to an electrical shop and have it repaired. Most of the time, it's the internal diode(s) that has failed.
Rod
