RS12Turbo »
https://forums.nicoclub.com/rs12turbo-u46243.html
Wed Nov 04, 2009 4:02 pm
I think I might of figured out my wot cut out issue....I actually used the search feature, and have come to the conclusion that my maf is maxed out. I went out today and did some runs....
First pull: 4th gear; when it cut out afm was 83.6%; Boost was 12.8 psi; Outside temp was around 50 degrees
Second pull: 2nd gear; when it cut out afm was 95.6%; Boost was 13.7 psi; Outside temp was around 50 degrees.
Set-up is:Evo 3 16g, custom header, 3" turbo back exhaust, fmic, walbro 255, nismo fpr, cai, S-afc 2
Afr's are high 11's. Is it time for a z32 maf?? Thanks for any help
