f150intally »
https://forums.nicoclub.com/f150intally-u5432.html
Fri Feb 13, 2004 7:12 am
Dude, In all seriousness.... a T3/T04E turbo @ 12psi on the stock injectors and MAF is living dangerously. Be careful not to melt a piston. You can't always here detonation. Some of it is inaudible but I would be guessing that you are running dangerously lean in the upper rpm levels, even with the AFC.
anyways, just wanted to let you know to be careful. Those turbos flow a hella lot more air than the T25. Z32 MAFs are pretty cheap.
If you cut the VSS wire you will not have a speedometer. I think what you are referring to is the 5th gear sensor, but you will want to double check.
-Jay
