Max. Tire and Wheel Combo
Shocks, springs, sway bars, coliovers, bushings, brakes, wheels, tires - This is the place to discuss G-Series suspension modifications!
OH6 G35
Car: '06 G35 IP Coupe/5AT
What is the "widest" wheel and tire (size) combo (front and rear) that you can put on a '06 G ?...any pics ??
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
9.5 up front and 10.5 in the rear should be all you need, even with forced induction.
NoneRock
Car: 2003 Infiniti G35 Sedan
It this true for sedans as well?
Thanks.
RED_DET
Vendor
2011 Infiniti G37x
8.5" is the widest wheel you can run on the sedan up front. 9.5" wheel in the back, you might be able to fit a 10" wheel in there with the right offsets. But I think a 9.5" wheel in the back with some 275's will be all you need.
NoneRock
Thanks, that's what I wanted to hear.
Astro1
Car: 2003 Infiniti G35 Sports Coupe
Red any idea what the widest rim would be for a 03 sport coupe .. front and back ?
I am looking at these
http://www.streetdreams.org/wh...t=100
Front Size: 19 x 9 Finish: Chrome Offset: +30mm Bolt Pattern: 5x114.3 Price Each: $355.00 Rear Size: 19 x 10 Finish: Chrome Offset: +30mm Bolt Pattern: 5x114.3 Price Each: $390.00 Front Size: 245/35R19 Sidewall: BSW Treadwear: 280 Performance: UHP Price Each: $197.00 Rear Size: 275/35R19 Sidewall: BSW Treadwear: 280 Performance: UHP Price Each: $242.00
RED_DET
Vendor
2011 Infiniti G37x
Personally, those offsets are a bit too weak. Check this out:http://forums.g35club.org/zerothread/342067
The OEM offsets are 30mm for 18's and 30/33mm for 17's and you see how far they are sunken into the wheel well. Browse through that link and take note of the very aggressive and aggressive setups for the g35 coupe.
This website is also very helpful, http://www.1010tires.com. Under the wheel tech category there is a wheel offset calulator. All the information needed for the oem specs are in the link above. Just plug in whatever wheels you are looking at and see how things work.
Astro1
Thank you Ocifer ..
Appreciate the help !
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
