Bronze MFP »
https://forums.nicoclub.com/bronze-mfp-u7726.html
Thu Dec 21, 2006 6:27 am
245/40 tires should not be a problem. the rear you can go wider, but up front 245 is as wide as i'd go. just make sure the offset of your wheels doesn't suck. as an example i'm running 17x8" mustang wheels with 30 offset. the front fitment is perfect, the rear I could def. go with a wider tire.good luck!
