Max Power on a Blacktop SR20det
Nismo20
Car: 1989 NIssna 240sx with S14 Blacktop SR20DET
Right not my sr20det is dynoing 256whp and 256 torque. And i am still running stock injectors and stock turbo. But i am fixing to order some 740cc injectors. On the car i already have a greddy 3row fmic, megan full 3in. exhaust, megan down pipe, Nismo 9 puck clutch, wlabro 255 fuel pump, and hks ssqv bloff vavle. Does anybody know what the max power is of an SR20det before i need to start upgrading internals?
killablue240
Car: sr powered s13 coupe, 1991 twin turbo 300zx
about 400 tuned well
DemonicDonut
Car: 1990 240sx Hatch
also remember proper care. Change the oil when you should. Change coolant etc. Keep it fresh.
highmilehatch
Get yourself a Power FC and a larger turbo and your ready to make more power.
Keep in mind what you use the car for. As a daily driver, it's not very realistic to be putting 400+ the ground. I wouldn't worry too much about the internals if you take it to a reputable tuner.
Cheeks
Car: 90 S13
best power out there right now on stock internals was done by Hybrid Dynamics, they did 665whp on a screaming 35r.
White Comet
Car: fc, s13 and mazda6, Sierra
what boost are u at to put down those numbers, i would prolly dyno near that since our setups are almost identical
highmilehatch
You've got a 35R? I thought you said your on stock turbo? You'll need to spend a few thousand more to make that kind of power.
Nismo20
I dynoed those numbers on 15 pounds.
