240240 wrote:Donno the exact specs on ecuwould imagine--full exhaust, aftermarket turbo, injectors, z32 maf, ????
Are you still using a factory headgasket, also how long have you been pushing 20 psi?goofynick6 wrote:I run 20 psi with no problems on my 57 trim t3/t04e. You should be fine to 18-20 psi. Those injectors are more than enough as well.
Nick
Sweet got the problem fixed?goofynick6 wrote:RB20, Hess 93 octane..heh. Been running 18psi for a while, just went to 20 and I like it. 26 degrees timing at full boost.
I have .63 stage 3 wheel and 3" exhaust cutout on the downpipe. I get 20psi by about 4600 rpms. It's a bit slow, I would definitely definitely have gone for the 50 trim instead of 57; better spool and efficiency with the 50.
330whp/305wtq btw
Nick
Why are you selling your car? What's the next project?goofynick6 wrote:I also think stock cams are the limiting factor in the equation. I am not changing turbos at this point, I'm getting ready to sell the car anyway..heh. It depends on volumetric efficiency, etc, but I think the compressor is starting to go out of efficiency right around when the cams are killing off the power band.
Nobody made 330whp on stock boost on a mustang dyno..not gonna in this car w/o a gt42 or something. Someone made 298 on 14psi with a 50trim on a dynojet, but like I said, a 50 trim is a much better turbo for this engine.Andrew85cm wrote:Dynojets read lower than mustang's was the point. If you were on a dynojet that number seems rather low. You might have other issues because I would imagine a lot more power can be had at that high of a boost level. Wasn't there another guy on this forum making similar numbers on a mustang with stock boost levels. I would check your stuff. Anyway not bashing my rb20 is as stock as they come. I agree with rbsileighty it should be your cams that hold you back in the top end. You go much past like 5500-6000 grand and power falls where as your turbo should be making its most power at that point. Dang rb20 heads. I am going to replace the cams as soon as I can get the money along with some valve springs ect and maybe talk to my machinist about bigger valves or if that is plausable without extreme modification of aftermarket parts to get them to fit. Anyway good luck with your build. I bet she still hauls. Nothing like putting mustangs in their place. I mean they weigh some 3800lbs or something so they need to figure some power to weight ratios and come meet again.~ANDREW~
What do you mean by that ?I you talking about RB20's or in general.goofynick6 wrote:
I'm talking rb20's...I don't think you'll see 330whp on 10psi on the rb20 w/o a huge turbo.SillyRB wrote:What do you mean by that ?I you talking about RB20's or in general.
Used an eprom emulator and laptop to tune it; modifies stock maps.RB20 Mistake wrote:Did you make 330 rwhp tuned? If so, what did you use to tune with? I also think these numbers are pretty low for 20 psi. I have a t3/t4 60 trim that I will be using on my 20 and I hope to see much more than 330 at 20 psi.
