Would those LED's you provided the link to be "plug and play" for the Rogue?Elton Noway wrote:My wife and I live on a heavily wooded lot and the drive way is a little over 200 feet long. Backing down it at night has always been a challenge over the years but its even more difficult now with our new Rogue and the 20% tint on the back window. Have never been interested in installing light along the driveway. Beside mod'ing the Rogue is more fun
Just wondering if any one has some good suggestions for maximizing the light output from the Rogues backup lights.
Thanks to the most excellent thread by Leo2005 (How to install LED kit in tail lights(finally got my project done) I've got a good handle on how to proceed. zerothread/326090
I believe the easiest fix would be to swap out the 921 bulb with some high power LED's. I found these... on V-Led that have an output of 200lm! ... but... I'd sure hate to blow $50 if it won't deliver the desired results (or not be a good choice for the Rogues backup light assembly. The other concern (maybe no big deal) is only 4 of the lamps fire forward. http://www.v-leds.com/Exterior....html
The other option would be to cut out the reflector and modify it in some way... i.e., to accept a mini reflector bulb ... or Hella maybe? My goal is to light up behind the vehicle like a set of small headlights. Sorry , not interested in bolting any aftermarket KC style lamps to the bumper. Just looking for something I can incorporate into the current backup light assembly. Ideally they will light up the drive way like a 747 coming in for a landing but not cause the lamp assembly to melt like a chocolate bar on a hot summer day.
Modified by Elton Noway at 2:51 PM 5/29/2009
Yes. Based on the other link in my orignal post (that takes you to Leo's thread) ... Leo actually did all the research. He states:Roguemeister wrote:
The V-LED bulbs I linked to in my bost (V-LED HID WHITE 14 M-SMT 5W HIGH POWER BULBS) are indeed 12V 921 bulbs. No modifications... no wiring... etc. NET: Plug and PlayLeo2005 wrote: First of all I would like to say that tail lights have bulbs 7440 and 7443 but 7443 will perfectly work on 7440. Back up lights have 921 bulbs
Hi Leo, Well... I didn't order the V-Led 200lm at $50! Once I read the great reply from Pescakl1 I wasn't willing to gamble $50. As it turns out... after much research, too many dollars spent, and much experimentation I've come to the conclusion that LEDs look cool and might be very bright to look at, but while they may appear more vibrant they don't disperse a lot of light when compared to halogens.Leo2005 wrote:hey Elton. Did you order these lights yet? VLEDs have led license plate. It seems to be a better solution. I think I'll order one for myself:http://www.v-leds.com/Exterior....html
Well, if I took it so far as to install the lighted bolts... I'd wire them into the circuit with the lighted license plate frame so they would only illuminate in conjunction with the LED's in the frame while in reverse.Leo2005 wrote:led bolts not gonna do anything but a small dot especially for backup reason. For visual look in this state it is illegal unless it's red.
Hi Pescakl1... thanks for the info link. At first I was thinking these might be just what the doctor ordered... but... I on further research I don't think taking a Dremel to my back up light assembly will be enough... the babies are just over 4 inches in diameter!Pescakl1 wrote:Elton, I may have found something for you: MODEL SL4800 from http://www.americansuperlite.com/back-up-lamps.cfmThey are for trucks and they are DOT approved.
BUT... as I don't use my car right now, you will have to check if they fit (but I remembered that I measure about 10 cm diameter for the back up lights housings).I don't know the prices either, so you will have to contact them.The guy who found these (on another forum) calculated that you should have about 480 lumens as output as they are 3rd generation high power OSRAM LEDs.
Sorry for bumping my own post... but I never got any feedback from the electricians in this forum as to whether or not they thought the Rogues wiring harness could handle the extra current draw if I were to make this socket mod and install 50W Halogen back up lamps. I still think this may be the best solution.Elton Noway wrote:At this point in the game I'm still leaning towards modification. (replacing the 921 bulb socket with one of these 3156/7 sockets)...so I can install a 50W Halogen, and then cross my fingers the housing doesn't melt. Actually maybe even a bigger concern is frying the wiring harness if they were left on for an extended period of time. Any engineers in this forum that can give a definitive answer? If my math is correct... even though the 921 and 3156 bulbs are both 12V bulbs, the current draw will be 4 times as great by switching a the 50W bulb.
