Let me sum this up for C-Kwik. 10lbs of potatoes wont fit in a 5lb sack. Unless you compress them in a trash compactor first.C-Kwik wrote:I'm not sure where this "rule" came from, but when you're boosting, in theory, you should be making nearly as much power over NA as the pressure ratio the turbo is operating at.
Any orafice, such as the head has flow limitations based on mass for a given density. In other words, it will flow a certain volume of air. But if you increase the density of air by increasing the pressure, a higher mass of air will fit in the same volume. If it flows based on volume, there is no theoretical limitation on mass flow as dinsity can be increased as much as everything else can handle.
We measured 15% transmission loss on the S13 with CA and manny transmission, should be the same.KATwo40 wrote:The stock cams start to choke a little when you get into the 430ish whp range. So, that'd be what, about 500bhp?
there have been plenty of people to push 500+whp and 600+whp using stock cams (Rick, Duy, Anthony, Barney, PhatKA-T car, Mike Lee, etc)...if someone's KA was "choking" out at 430ish whp, then it was prolly their turbo maxing out or they werent pushing enough boost.KATwo40 wrote:The stock cams start to choke a little when you get into the 430ish whp range. So, that'd be what, about 500bhp?
I know but the "rule" I talked about is just an old (not perfect) way to calculate cam and head flow when you boost N/A engines.No sciense, just a fast guess before you start calculate things.And the stange thing is that it often turns out really well.C-Kwik wrote:I'm not sure where this "rule" came from, but when you're boosting, in theory, you should be making nearly as much power over NA as the pressure ratio the turbo is operating at.
I'm doing about 500bhp on stock head/cams right now.Swedish Mike wrote:If you use the old x3 rule the KA head should flow 155x3=465bhp when boosting it.(Of course with a solid bottom end and good tuning, we only talk flow now.)How far from the truth is this? Anyone pushed over 400bhp on stock cams and without porting?
155 is a number I had in my head, not sure if it´s correct for the KA24DE?
That´s just amazing, ported?nissanfanatic wrote:I'm doing about 500bhp on stock head/cams right now.
Good job! The KA is crazy...nissanfanatic wrote:No, stock.
I stand corrected. Thank you for clearing that up for me. This gives me good vibes about running stock cams w/ mild porting.klattr1 wrote:there have been plenty of people to push 500+whp and 600+whp using stock cams (Rick, Duy, Anthony, Barney, PhatKA-T car, Mike Lee, etc)...if someone's KA was "choking" out at 430ish whp, then it was prolly their turbo maxing out or they werent pushing enough boost.
This isn't always true. For example, the SR head / cams go sonic at around 330whp, regardless of turbo capability. This has been documented many times and there are tons of dyno sheets proving this.C-Kwik wrote:I'm not sure where this "rule" came from, but when you're boosting, in theory, you should be making nearly as much power over NA as the pressure ratio the turbo is operating at.
Totally off topic but is it common to use the SR N/A head or cams on the turbo models in USA?According to a buddy (tuned the 915hp one) the N/A head were much better.That was the big difference between the 885hp and the 915hp engines, turbo vs N/A heads.KATwo40 wrote:This isn't always true. For example, the SR head / cams go sonic at around 330whp, regardless of turbo capability. This has been documented many times and there are tons of dyno sheets proving this.
I guess you´re on forged internals now, if not, add that to the 264´s.nissanfanatic wrote:Thanks!
On my next setup, I'm definitely going to at least run 264s... Hopefully I can get some porting done on the exhaust side as well...
I guess I was thinking about a smaller picture when writing this out so I really only considered flow in terms of volume, but not the changing pressure across an orafice. I'd be curious as to where the SR heads/cams are finding this limitation. Is it the ports themselves or the valve area vs the cam's lift and duration? When air hits supersonic speeds in a head, it's probably going to be in the exhaust side and likely due to a large pressure differential. If larger cams can aleviate the problem, then I'd have to believe that the port is not the problem, but rather the valve opening.KATwo40 wrote:
'KATwo40 wrote:Ckwik: The SR guys always alleviate the choke with upgraded cams, so I'd venture to say it's duration that's the issue. I suppose stock cams with larger valves could be used, but simply swapping cams is much less involved.
Greddy intake manifold works wonders for them too.KATwo40 wrote:Ckwik: The SR guys always alleviate the choke with upgraded cams, so I'd venture to say it's duration that's the issue.
Then there would probably be little need to port unless the cams get upgraded first and you still run into a flow issue. This could be true for the KA as well.KATwo40 wrote:Ckwik: The SR guys always alleviate the choke with upgraded cams, so I'd venture to say it's duration that's the issue. I suppose stock cams with larger valves could be used, but simply swapping cams is much less involved.
That´s often a problem you see on N/A heads, as boosted they can take you to high numbers with everything stock but when you upgrade cams the exhaust ports says no.Often easy to port up and never any intake port problems as the small port turbo heads.C-Kwik wrote:Then there would probably be little need to port unless the cams get upgraded first and you still run into a flow issue. This could be true for the KA as well.
