http://www.rceng.com/technical.htm#WORKSHEET
I think its a little on the conservative side but using 43 psi, 80% duty cycle, and a BSFC of .65 (just to see the limits), it comes out to right under 350 bhp. Fuel pressure can be turned up and the BSFC is likely lower than that.
Take the VG30ET for instance. Guys are pushing 420's well over 400 whp before maxing them out. Not sure at what pressure but the duty cycle is likely no more than 80% (I think that's where the ecu caps it). Say if they were running 80% duty cycle at 60 psi aiming for 450 bhp, that would be a BSFC of ~.50.
You can mess around with that thing and get some ideas. Like I said above, I think the ratings are definitely conservative.
I think you're right on the 555's though. Just as comparison, I think most Z32 guys run the 555's up to around 500 hp. With a couple more injectors in the engine, it can be more than that. Basically, I would say 600 hp with 555's would be cake in the VH.... I think its time for me to go to bed.
