MAX HP FROM A STOCK RB25 EX MANI
Chaos the Xile
Car: 1974 Datsun 260Z
Just out of curiosity and well technical reason for a project that I am beginning, how much horsepower are you making from your stock rb25 exhaust manifold??
If you view this thread can you please put a quick reply if you apply to this application. Thanks.
240z4u
Car: '95 Nissan 240SX
I have seen over 500whp on a stock manifold
SullivanRacing06
Car: r32 gtst, 06 350z, r32 gtr, rs4 steaga, 04 350z, f350/6bt
bounty212
Car: s14 zenki SE w/rb20
hateeee to threadjack but.. does an aftermarket rb26 manifold fit rb20/25? are the port pattern/bolts same so its just that the 26 is tt that makes the difference?
Chaos the Xile
bounty212 wrote:hateeee to threadjack but.. does an aftermarket rb26 manifold fit rb20/25? are the port pattern/bolts same so its just that the 26 is tt that makes the difference?
no the rb26 has a different bolt/flange pattern than the rb20/25
SullivanRacing06 wrote:500+
ok cause i was thinking about using a stock manifold to start my compound turbo prototype, but i wanted to make sure the manifold would be up to take to flow enough air for over 700hp eventually. maybe the hks cast would be a better choice?
flatrate
Car: S14 kouki
invest in a good manifold, boost control, response , etc will improve vastly over stock...that stock manifold isnt enough for anything over 400 whp imo... can you make 400-5 on a stock manifold sure but your starting to sacrafice efficiency
Chaos the Xile
yeah i am wonder becuase i am working on a compound turbo kit for the RB's and i wanted a little variety, if the stock mani can flow over 500 then I might make a custom up pipe kit for it, but i will probably stick with making a custom manifold!
flatrate wrote:invest in a good manifold, boost control, response , etc will improve vastly over stock...that stock manifold isnt enough for anything over 400 whp imo... can you make 400-5 on a stock manifold sure but your starting to sacrafice efficiency
