MAX fuel pressure on BD top feed rail
sunnys14
Car: S14
whats the max pressure that the boost designs fuel rail can hold? anyone know? also what is the max pressure the stock fuel rail can hold?
Warped
Car: 1993 240sx coupe - 2000 Audi S4 Stage 3
seems it can hold over 120+psi since there have been people using a 12:1 fmu on stock injectors and rails and have no prolems
sunnys14
Car: S14
can anyone else confirm this?
fiznat
Car: Grown up :(
I have never ever in my entire life heard of someone actually blowing a fuel rail up due to high fuel pressure. Its really not something you need to worry about at all.
Warped
i would worry more about the lines than the rail it self
Structure240sx
the BD rail doesnt use the stock injectors. they offer it as stage II i believe using 52# injectors which elimnates the need for the fmu
fiznat
Car: Grown up :(
I just did some quick research on fuel lines... standard steel braided line has a burst pressure between 175 and 200 psi. You should never be that high anyways. Assuming all your fittings are quality and in good shape, there should be no reason to worry about your system actually bursting from too much pressure. If you have to jack the pressure up that high anyways, you're doing something wrong... just get bigger injectors.
