max bore
celica-punto8
hi! new guy here scavenging some info:) i looked around but didnt find anything, whats the max safe size i can bore a ca block? thanks any info be welcome.
Dirty Dee
Car: 1989 240sx
From what I have read, I think you can bore it out so it will be a maximum of 1900cc's. so 85mm.
celica-punto8
bump for more info on oversize! plus another post, to reach the 10 post rule
themadscientist
I would not punch it that far. I will have to go 85mm on mine and there is very little meat left between cylinders.
dattodude
Car: CA18DET Datsun 1200 B110 Sedan
20 to 40 thou is rule of thumb. Unless it's a drag motor that you are prepared to 'lunch' during a run.
For a street car, many people are running 40 thou, but if you get a block with bores slightly offcentre (not uncommon), you risk busting something under 'man sized' boost.
Hope my advice saves you one rebuild.
The_Chosen_One
Car: 2009 Subaru Impreza 2.5i
Nismo use to make 85mm pistons for the CA, as far as I know they are the only ones to sell a piston that large for the CA.
celica-punto8
http://www.paeco.com The price for a set of forged pistons in standard bore, stock compression ratio is $420. Add $40 for any overbore size and add $40 for any non-standard compression ratio. We can furnish virtually anything for this engine that we furnish for any of the other Nissan engines, provided that you can furnish us with stock part samples to go by. The parts are necessary since this is a non-imported engine. The pricing for everything would be the same as for listed items, since we do most of it on a custom basis anyhow. Please let us know if we can help you. - Carl at PAECO
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
How long did it take you to get that reply? Sometimes it takes them months. I dont really trust them.
celica-punto8
less than 24 hrs, i used them before for my 3tc engine, i got an stroker kit, it made my 1.8 into a 2.3 hahahahahaha. i never had a problem and it was good quality. now thats my experience.
sideways danny
Car: s13, CA18DET
the CA20 block should be useable with some modification, it is slightly taller (2-3mm i think i worked out) and uses an 84.5mm bore as standard. There are 85.5mm pistons available for it (not suitable for turbo use, but you could have them made by special order)
Infact if you managed to get hold of a Tomei stroker crank you might be able to get upto around 2050cc like this. wish I had the money
themadscientist
a "tomei" crank is just a CA20 crank with a different snout for the CA18 belt gear.
sideways danny
Car: s13, CA18DET
themadscientist wrote:a "tomei" crank is just a CA20 crank with a different snout for the CA18 belt gear.
the standard CA20 crank isn't forged (the CA18DE/T crank is), so is no good for any real power
themadscientist
Keep the revs low and use the stroke to make the power and it would be fine. The CA20's achilles heel are those supemodel-sized con rods.
celica-punto8
no guys if anything i would either machine the crank .250 or just leaving it the stock bore but raise compression couple points. im not looking to run 25 pounds of boost, 15 or so with a 9.5 to 10 to 1 should be ok, maybe a lil alcohol or water on the intake side to keep things safe.
