rbsileighty »
https://forums.nicoclub.com/rbsileighty-u4927.html
Fri Aug 27, 2004 8:12 am
My trim level is small (not sure since it was second hand), and the turbine is a .48 a/r which is why I'm going to need boost to pull some power out of it.
The comp map of a 46trim T04E is showing it's maxed out 42.5lbs/min out to 60% EFF when running ~18psi . Granted this is far out of optimal eff... but the flow at 7800 w/ 18psi out of the RB20 is ~33lbs/min which is in the 74% EFF circle (with the .48a/r it might be out in the 60% range again).
I have a scramble button on my Profec B, so that's what I was thinking I might set it to if it doesn't start detonating out there. With the 46 map @ 7800rpm w/ 12psi I should be putting out 27lbs/min (72% eff)... so that might be my normal boost range.
These boost levels are all inside the 50 trim T04E, but I really have no idea what the compressor side is on this turbo (what happens when you are pressed for time in purchasing... wouldn't have bought this one if I had thought more about it). It is a turbonetics polished housing with no numbers on it.
Does anyone have specs of the different ones? What is the diameter of the inlet on a 50 and a 46 trim? I have seen a few VW combos that are for the 1.8 (this one was bought originally for a honda) that are running a .48 turbine w/ a 50 trim, so I'm hoping since it's a turbonetics turbo and maybe for some B18... I'm dealing with the same. I know this one is bigger than the Saab T3 inlet we have laying around.
How do the 2L 4G63 EVO VIII's pull 19psi with a 8.8CR if we can only run 15?
