Just beware of the timing. As for fuel and AFRs, you seem to be pretty good.turbo-sil40 wrote:My question is am I able to run 20psi on this setup-
GT2876R
Equal length manifold
SAFC2
Greddy profec B spec 2
Venom 720cc injectors
bottom end freshly built
Full exhaust 3.5 in. to 4 in.
walbro 255 pump
nismo fpr
N60 MAF
Took it to the dyno to correct A/F the car ran 12.0 just about all the way to 7200 rpm on 7psi just for a break in and it made 190.35 hp and 166.79 torque. Run conditions were 77.64 degrees and humidity was 10%. Now i wanna punch it up, do I have enough to run 20psi or do I need something else.
