max boost
r32gst
Car: r32 gts
i have a 90 240sx se. sr20det redtop. greddy oh5-18g turbo 880cc injectors walbro 255, down pipe, 3in all the way, fpr, hks evc, afc stock sr20 ecu, welded rear diff, full greddy piping and front mount, hsk ssqv, plx WIDEBAND.
what do you guys think i can run max boost...
just trying to get a good feel of where my car is....
and what can the internals handel boost wise i've been serching all night?
Modified by r32gst at 7:29 PM 7/20/2009
zach-Ka
Car: 1990 240sx (SR)
zerothread/306956With a tune you could maybe do more.
r32gst
Car: r32 gts
it helps a little bit. what do you guys think of the set-up
nisjay
Car: 240sx
I was boosting 1.4 bar on my 180sx with a black top when I was in Japan. I think that's 20 or more pounds. SR's can handle a grip of boost. my ish was running strong to, it would definitely snap your neck back.
maryjane
do you have a wideband?
what were you running on a daily basis, whats your afr at wot?
maryjane
your h/g is a limiting factor as well
r32gst
Car: r32 gts
maryjane wrote:your h/g is a limiting factor as well
whats h/g mean.... i've been just tuning on the afc 1
maryjane
head gasket and afcs are not good news. rom tune ecu and wideband are better then afc tuning.
r32gst
Car: r32 gts
maryjane wrote:head gasket and afcs are not good news. rom tune ecu and wideband are better then afc tuning.
just wait ing on some cash befor i can rom tune
r32gst
Car: r32 gts
so i have my 240 running 16psi. the a/r is 11.2- 117 in wide open. it's running super smooth. i love the power it's making. i just wish i can up the boost to 20psi or so... i have my boost controler max out. is there anything i can do to get more boost.... w/out pulling the vac off the wastegate
nisjay
Car: 240sx
Get a new boost controller. Do you have a T25 or T28? I would say 16psi is a good amount for daily driving an SR. Those are really strong engines. Like I said I was boosting 1.4 bar and ripping on it everyday, I never had a problem. It was a skyline killer, GTST anyway.
r32gst
Car: r32 gts
right now the turbo in the car is the greedy 18g. i still have the t25. the disco. i wanna sell it, it just sits here now. oh and i'm on 18 psi it's so much fun
maryjane
well if the afrs are in the 11s then your fine what w/g are you using? upgrade to a hks actuator to up it
