Max boost on Pump gas (91 octane)?
240SXer
Car: 1995 240sx SE (2jz powered)
yes, I used the search and can't find anything.
I was curious, i'm gonna be running a S13 blacktop with a big hybrid skyline intercooler, and a greddy boost controller. I was curious, what is the max amount of boost that can be ran on pump gas without detonation? I've heard 10 psi, 12psi, 14psi, just about everything. I know the injectors can only handle 14psi, but can you do 14psi on pump gas?
Thanks....
S13240
Go Dyno
RobDET
Car: Cars
for the past couple weeks i've been running 12 psi with the timing accidentally fully advanced and i had no audible detonation. The car was really fast tho!
240SXer
So with timing slightly backed off I can run 12 with no problem? How about 14?
RobDET
Car: Cars
I run 12 every day all day but we have 93. I have run 14 for several days with no isses though.
240SXer
I only plan on boosting up to 12-14 specifically for racing. Otherwise I'm gonna run stock boost.
