Yea, my friend ran 15 on a stock sr20, and blew it. do 12 to be safe cuz if it gets cold out side then it could be like your really running 15 or what not cuz when it gets cold you boost goes up.ILikeMy240sx wrote:Stock T25 + 370ccs + Stock MAF + Walbro + FMIC
14 psi and you are VERY close to the max limit.
I wouldn't push more than 15 psi on that setup. After that the turbo is way out of its efficiency range.
[email protected] wrote:S13 Red-Top T25:Compressor: T-25, 60 trim 56mm 0.64 A/R BCI-1 compressor.Turbine: T-25, 62 trim 53.8mm 0.80 A/R turbine housing.Stock Boost: 7 psiSafe Boost: > 13-15 psi After that The Turbo is past it's efficiencyMax Boost: 17 psiHP Ratings: 240 - 250 RWHPType of Bearings: Journal Bearing
S13 Black-Top T25:Compressor: T-25, 60 trim 56mm 0.64 A/R BCI-1 compressor.Turbine: T-25, 62 trim 53.8mm 0.80 A/R turbine housing.Stock Boost: 7 psiSafe Boost: > 13-15 psi After that The Turbo is past it's efficiencyMax Boost: 17 psiHP Ratings: 240 - 250 RWHPType of Bearings: Journal Bearing
S14 Black-Top T28:Compressor: T-28, 60 trim 60 mm 0.60 A/R BCI-1 compressor in T-04B housing Turbine: T-25, 62 trim 53.8mm 0.64 A/R turbine housing. Stock Boost: 7 psiSafe Boost: > 13-15 psi After that The Turbo is past it's efficiencyMax Boost: 17 psiHP Ratings: 270 - 280 RWHPType of Bearings: Ball Bearing
S15 Black-Top T28:Compressor: T-28, 60 trim 60 mm 0.60 A/R BCI-1 compressor in T-04B housing Turbine: T-25, 62 trim 53.8mm 0.64 A/R turbine housing. Stock Boost: 7 psiSafe Boost: > 15 - 18 psi After that The Turbo is past it's efficiencyMax Boost: 20 psiHP Ratings: Approx. 300 RWHPType of Bearings: Ball Bearing
