for a hypothetical situation.. injection would prolly be 450cc dsm with 255lph fuel pump and hks s-afr with a z32 maf. Ignition.. some sort with a spark enhancer combined with boost-based retard system. Tuned on dyno with all the sensors it needs
im just worrying about the max boost on stock on internals cosidering everything else is done as it shud be. Obviusly u prolly cant run much more than 4psi on an 11.5 : 1 CR. What would would be a figure for a 9.5:1 motor
alcohol water injection... i guess anywhere from 50% to 100% water, injected after the turbo. Uhh i dun know much bout water/alky systems. I bet u do
