McAdam »
https://forums.nicoclub.com/mcadam-u5096.html
Mon Aug 25, 2003 7:39 pm
are you talking about the VG30DET that cam in the cima? I am aware of that motor, but I was not aware of the fact that you could bore it to a 3.3L.
another interesting note, I have a detailed diagram of the 300zx (Z32) front suspension, and I don't see why it won't bolt into a 240sx. From the diagram, the front suspension is set up identical to the R32 skyline front clip that my freind sourced his RB20DET from. It still has the lower control arms that bolt to it in roughly the same place as the 240sx, only difference is where the engine mounts. Obviously, the engine mounts are further back on the Z32 crossmember, but everything esle appears to be the same. The Upper control arms bolt on to the body, so thats no problem.
I am not trying to sound like a **** here, I am just genuinly curious, but what makes the 300zx (Z32)front crossmember not bolt into the 240sx chassis? as long as the space between the chassis-to-crossmember bolts is the same, it shoudl be a bolt in affair. there is a dude running around town with a Z32 that stops and talks to all the other kids with imports, maybe he'll let me jack up his car and take a few measurements, I'll know by friday.
McAdam
