So I pulled out the old calculator, pencil, and a tape measure today...Only managed to confuse myself more...
So anyhow, anyone who can answer me a solution to this problem...
Stock Wheel- 15x6 +38= 152.4mm Width 38 offset
Looks like---> 152.4mm ---------------------------- | 38.2mm | 114.2mm |
Head on view of a tire if only viewing the top 2 inches of a tire. Now I measured fender gap and it looks like I would only need roughly 1.5 inches of extra width to flush out the wheel. So basically if I was looking for a 17x9 +~~ I would be looking at something like this-->
228.4mm ----------------------------- | 76.2mm | 152.2mm |
So if math serves me correctly if I was looking for a 17x9 wheel to flush out naturally without fender modifications I would only be looking for something with the same +38 offset?
Of course it won't fit on stock struts and springs but I figure I'd be gaining an extra 2 inches of rough clearence with coilovers so the inside should clear 152.2<164.2.
My question is basically am I doing my math wrong? Near everyone I've talked to says that you need +15 to +25 offset for a S13 chassis.
When you drop a few inches with coils does your stance change that drastically where you need another inch of width to flush out wheels and/or clear internal components?
