Matching the VIN to the engine
NihmX
Car: 92 S13
About a year ago my cousin passed away leaving behind his cherry S13. The odometer reads 227k, but I have service records for a lot of repairs that he had done to it in the last couple of years. In the course of having a new cat put on, the mechanic asked if the engine had been swapped out, as it did not run like it had 227k on it. Sure enough, a family friend had indicated that the engine had been rebuilt/replaced about 30k ago. Unfortunately they are no records for this particular service so my question: Is there a way to match the serials on a 92 S13 coupe, or a way to find/indentify the year the engine was made from a serial/block code/vin/ein? Or failing that, any other reliable way I can tell if the swap has been performed?
tl,dr: how can I tell if my engine has been swapped/rebuilt
thank you very much!
zenkistic
Car: 96 240 SE
Google search result:
On 90-92 KA24DE engine the "serial number was stamped on the left side top edge of the cylinder block (near bell-housing) when viewed from the driver's seat."
source: Chilton's via 240sxforums.
NihmX
Car: 92 S13
found that, found a number, but its not a complete vin as far as I can tell (751502x) with a small (B) stamped under it. I can find nothing online about what this number means, or what -if any- relation it has to the chassis vin.
thanks again! :)
zenkistic
Car: 96 240 SE
a guess would be that these 6 numbers should match the last 6 numbers of your VIN. I can go to my car and take a look.
NihmX
Car: 92 S13
that would be a big help, as mine do not match (101054) are the last sic of the vin
zenkistic
Car: 96 240 SE
sorry mate, I ll try to check it tomorrow, I actually went to check it but I found an issue with my harness. In the meantime, I am bumping this in case someone knows...
ash16847
Car: 1989 240sx hatchback
1991 240sx hatchback
Is there any way someone could take a couple pics on how to get to it, because on my 91 chuki I cannot find the number.. and I was told there was a swap when one of the previous owners did a 5 speed swap so id like to find out....
thanks
zenkistic
Car: 96 240 SE
For kade
[from 96 fsm under "General Information"]
Can a fellow niconaut do the crosscheck?
NihmX
Car: 92 S13
That's the spot. Pretty easy to find with a flashlight. Will try And take a pic later.
ash16847
I looked, with a flashlight, and could not find it... I looked, believe me. lol
NihmX
Car: 92 S13
when its light out tomorrow I will take a picture and circle the number. Also, I just confirmed that the engine has been replaced, and my VINs dont match. Can anyone confirm that if the engine is original they would match?
ash16847
Well, would the same work on a SOHC? I can always look on my 89 pignose if need be... the chuki is red '91 the pignose is purple 89 :P XD
NihmX
Car: 92 S13
I dont know, I can only confirm the location for a DOHC motor.
ash16847
^ Get pic yet?
