Hi, I wanted to know if the items below would fit correctly in my V. Specially the head unit since a versa needs something higher than this alpine unit (is there an installation kit that comes with it?)
I would also like to know if you recommend using this subwoofer and amp together.
I wanted to make a custom box myself to fit it perfectly in my versa, is it a lot of trouble?
I would also maybe need a bit of help for the wiring. Maybe some tips to know how to pass the wires to the trunk of the versa. Is lifting the carpet and passing the wiring under a lot of trouble? I need tips on grounding it too.
I have the S model and i was wondering if i would maybe take the wiring already passed to the trunk, but I cant find it (dont know how to open the side) and i'm not sure it would be big enough (gauge). Some pictures would heklp if someone has already done this.
Alpine CDA-9884 (head unit)Alpine KCE-422i (connector Cable)Pioneer TS-W307D4 (subwoofer)Pioneer GM-D7400M (Amp)
If these do not fit, would you have sugestions of what to get?
Thanks for your advice and help Paul
Modified by Paul . at 1:36 PM 10/5/2008
