match porting headgaskets to water passages in block
CA19DET
do any of you guys match port your headgaskets to match the water passages in the block, i see that the stock head gasket as well as the HKS metal head gasket i have blocks off one or more water passages in the block to the head, do you guys match port the gasket to allow water to pass through this passage??
others say they do it on DSM's and other engines for HIgh HP applications...
any CA builders ever done this.. or think i should?
boost_boy
I guess it won't hurt much to do it. My NISMO gasket came already with matching ports as well as my 2mm copper gasket. If you can open the gasket up without distorting it, I say go for it.
Dee
CA19DET
thanks Dee :)
Myetball
Anybody know why in the world OEM gaskets come with certain water ports blocked off? My E16s was the same way.
float_6969
To make us wonder why the heck they did that?
Nathan
Its to direct water flow to the back of the block, then up into the head, then back towards the front of the motor. If those ports were open then most likely, water would stagnate in the back of the block and head, making it run hotter on those back cylinders.
Myetball
float_6969 wrote:To make us wonder why the heck they did that?
:D :D :D
float_6969
You'd probabally better listen to Nathan, I'm just a smartazz...
iliketocrash
Nathan wrote:Its to direct water flow to the back of the block, then up into the head, then back towards the front of the motor. If those ports were open then most likely, water would stagnate in the back of the block and head, making it run hotter on those back cylinders.
so just to be 100% clear... you're saying to just leave the headgasket as is and that those water passages are supposed to be blocked off?
Nathan
Yes, thats what I'm saying :D Tomorrow I'll dig up some old threads about it, one I think I started even ;)
Nismo1182
Car: Z06
I wondered about that also, but if Nissan made it that way, then I guess it was good and I should'nt mess with it.
Notchbackca
Car: guess...
hey ca19, when you gonna sell me a manifold? :D
nismoplsr
this might be a stupid comment
but are you sure you are putting it on correctly?
IIRC when i put my new gasket on it almost fit one way, but some of the passages were blocked off. so i tryed to put it on a diff way and everything lined up perfectly.
NeedCAforS13
Car: CA swapped S13 coupe
see how the water jacket is clearly visable on the far left cylinder (#4) but on the other ones there is just a small hole on the bottom to allow water to pass through... its on there right;)
Sean
nismoplsr
oh yes
maybe i should have looked at the pictures first.
on my gasket all cylinders were ported like #4
NeedCAforS13
weird... both gaskets off my silvia motors (CA18DE and CA18DET) matched my new one exactly! which gasket are you using?
Sean
nismoplsr
the brand is Nippon Reinz
i was in a hurry and ordered the gasket set overnight, so i could get my car back on the road asap.
and i am almost 100% posative that it had full coolent ports on all the cylinders
iliketocrash
NeedCAforS13 wrote:
i'd just like to say that that picture is beautiful.:ylsuper
NeedCAforS13
why thank you! you like my crazy domed pistons do ya :pface we'll see how that works next week sometime...
Sean
float_6969
High compression turbo motors are a blast... till they blow up.
