master window switch
moneil4
Car: 06 infiniti m35x
does anyone know how to access master window switch on 06 m35
svard75
Car: 06 M35x
Open your window all the way.
Remove the handle escutcheon. This is the piece in front of the door latch that opens the door from the inside. Remove the screw.
Remove the arm rest finisher. Small plastic piece underneath the grab handle on the inside of the door. Remove the screw.
Insert a thin screwdriver from the armrest finisher opening and lift the lock of the power window switch harness connector.
If you need to remove the entire door assembly then at this point just use a clip clamp removal tool or a very thin flat head. Work your way around the edges disengage all the clips and then disconnect any wiring harnesses.
moneil4
I got it and checked voltage at the connector and had power. was really hoping it wasn't the bcm and with power to switch that appears to be the case. going to get a used switch and hopefully that's it. let you know how I make out. thanks
Costee
Car: 2006 Infiniti M45 Sport
2012 Nissan Murano SL
msvara wrote:Open your window all the way.
How is this done? By pulling it backwards or flipping it out from the edges?
Switch Doctor
Car: 87 Saab SPG
I wouldn't try my luck on a used power switch http://www.switchdoctor.net Lifetime Warranty 30 day return policy. If you do not see it on the site, call the number.
