The pedal by the firewall has a little bit of fluid by it when I was going to check the adjustment bit. Is my master out?
I bypassed the dampener by bending the line back with no kinks or anything. I can see the little metal rod coming from the slave cylinder moving a bit while I bleed but the pedal still will stay to the floor with very little resistance. It will pop back up when pulled too though.
When bleeding I am putting in fluid so would that count out my CMC?
If you have any more questions just ask. Don't really want to deal with putting in a new CMC but I'll do what it takes.
