Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Wed May 04, 2005 3:53 am
your main hope is to cut it out like Al did. I've ran into the problem that I can't find a fitting that fits. no pun intended. It should be a snug fit to the point that it will be pressed into place by the line when you install it. I have cut up an S13, an S14, and a Z31 MC with no luck. They're all too small. This seems to be a problem when you buy parts from aftermarket manufacturers like AC Delco and the like.
