ARKQX33V6 »
https://forums.nicoclub.com/arkqx33v6-u165721.html
Tue Aug 09, 2011 1:53 pm
Master cylinder, the reservoir at the firewall with a vacuum booster and the brake pedal assembly attached that you push with your foot to engage the hydraulic brakes, yes.
If this is what your discussing, when you did put another in place did you attach and level and place all bolts loosely and check plunger piston operation and vacuum operation before trying to drive.
The M/C is hydraulic in nature and must be balanced mechanically and hydraulically so the piston operation is smooth and level. Otherwise excess pressure is applied to the container which is just a tank and has no pressure or can it take pressure.
When it comes to draining and replacing brake fluid there is no fast and simple easy method. If the vehicle has 4 wheel hydraulic brakes, ABS, a master cylinder, an e brake, then each wheel, ABS and M/C must be approached on time in correct order, usually from farthest from the M/C to closest. The M/C should be flushed by vacuum before pumping fluid, and topped.
The brake draining is done at each wheel whether drum or disk, the relief valve drain point must be clean. Tighten each as you come to it and then try to open. If you open first it may be rusted and break.
A coke bottle, a 1/4" tube and tight fitting is essential. 2 people is nice to do the job, or even an automatic bleeder, but not essential. You must know the difference between clean and dirty brake fluid and know the dangers of the wrong fluid and the mixing of paint and brake fluid.
Many people create more problems than they resolve do a brake job and fluid change because of inexperience, cleanliness or lack thereof and being in a rush. If 2 of you are doing the job COMMUNICATIONS are vital, the person pushing the pedal and releasing it needs to take orders from the guy collecting the fluid so he can be certain the valve is closed at the right time.
Also the pusher of the pedal needs a stop, a 2x4 to restrict piston operation. Too much of any movement is a no no. That is when air can get into the lines and you want to remove air and never let it enter by not doing extreme pumps, orifice on off and being spaced out.
It will take time, be comfortable and don't get angry.
